Status
Not open for further replies.
joedallas
This will make me reconsider the engine choice for my 12
http://www.casa.gov.au/scripts/nc.dll?WCMS:STANDARD::pc=PC_102279
CASA is responding to a high, and increasing, rate of engine failures among aircraft that are powered by engines manufactured by, or under licence from, Jabiru Aircraft Pty Ltd (Jabiru). Such aircraft are referred to in this document as 'Jabiru powered aircraft'.
The issues appear to be the result of several failure modes, which require separate investigation.
CASA has formed the view that its functions under the Civil Aviation Act 1988 require it to mitigate certain risks to passengers, trainee pilots and persons on the ground.
Accordingly, while CASA works with Jabiru to identify the causes of these engine failures and to implement appropriate corrective actions, CASA proposes a set of operating limitations on Jabiru powered aircraft.
Status
