StressedOut
After dealing with J-stiffeners again as I start on the fuel tanks and OB leading edges, I was reminded of the struggles I had early in the wing build with the J-stiffeners. I cut from the wrong length stock and ended up having to spend $65 for new parts.
I put this table together with details of the RV-14 wing J-stiffeners that will hopefully prevent future builders from making the same mistake I did. Would it be possible to make this a sticky or include this post in the RV-14 wiki, or maybe both?
I came up with the same conclusion when I was also concerned about mucking it up!
