Dorfie
How does thread pitch affect strength, torque, tendency to loosen with vibration etc?
If same thickness bolt, same material but different thread pitches, how does it affect application.
I notice that the engine crank case halves are held together with coarser pitch (high vibration environment) than generally used in airframe.
Thanks.
Johan
Mel, I always figured they were course pitch because when Lycoming designed the engines, fine pitch hadn’t been invented yet..... ;)
No general conclusion there
Both of those fasteners are threaded bolts with nuts, known hardness and controlled thread fits. Vibration "tolerance" involves the clamped material, (steel-aluminum), washers (contact areas), stretch length of the bolt, and loading case (shear, tension combo).
Bolts can be loaded for shear or tension. Example is an RV wing attachment or a connecting rod. A connecting rod must have sufficient tension for tension loads and ensure the tension of the fastener creates a rod cap contact stress that it will not slide from side to side. The connecting rod bolts are a grade 8+ bolt.
The spar bolts are not intended to prevent shear of the parts under all conditions.
They are grade 5.
The only conclusion I can draw is that if the clamped parts separate or slide with loading they can come loose, but not based on thread pitch.
Way back
Fine pitch threads react to a torque value closer to the intended purpose of properly preloading the male fastener. They are also less susceptible to loosening than a course thread bolt.
Course threads are stronger in theory; a bet I would have lost. Despite fine pitch having more threads engaged per length, the course threads have more contact/load area engaged due to the thread geometry.
This memory goes back to Mechanical design class in 1985. No differentiation was made for aerospace grade fasteners if there is such a difference. Someone will surely correct me if needed.
