After spending the past couple of weeks laying on my back or side inside my cockpit "retrofitting" my RV9 with wall insulation, aleron push rod boots and now heated seats, I started to think how much easier it would have been for at least some of these things to have been done when the plane was built (or maybe even provisons made for installing them later). I'll grant you that a lot of builders who fly in southern climates wouldn't want or need some of these improvements, but my plane was built in Ohio. After talking to several builders who all claimed their biggest single improvement for keeping their planes warm in the winter came from the aleron boots, I got to thinking that probably no plane built above the Mason Dixon Line should be built without them. As far as I'm concerned, the same might go for insulating the cockpit or firewall.
I almost forgot the oil cooler shutter I have on order and yet to install so I can get rid of my winter blank-off plates, and maybe be able to make a southern trip some day without having to stop somewhere in route to pull the cowling and remove them when I get into a warmer climate.
Since many little items like these are 10 times easier to do during the building process, I was wondering if anyone has started a thread for new builders about adding things to their projects that they feel should be "standard equipment" with any kit sold by Vans. What would you add to the list?
