I'm at the point where I'm ready to rivet the bottom wing skins on. Is there anything from Van's that I should order that would be much easier to install prior to close out? AP servo install kit? I don't know what's in it or what it looks like. I'm installing the Dynon pitot mast and have done all the prep work for that. I ordered the aileron trim kit, but that looks ok to do later.
One item that I was wondering about was installing an Archer nav antenna in the wing tip. It appears that I need RG-400 for that. How much should I order? Will I use more of it later, if so how much? Just trying to order a qty that will eliminate waste.
Jeff
Jeff
