douglassmt
I'm just starting on CS propeller airplanes and making the transition to that third little knob on the panel in preparation for flying my RV. As the concept of manifold pressure was explained to me, it immediately occurred to me that it's not a pressure, it's a vacuum. As you open the throttle, it increases the air flow (and fuel) to the engine, but you quickly learn that the max manifold "pressure" you can achieve (on non-turbo engines) decreases with altitude and cannot exceed 30"hg at sea level. So manifold "pressure" is the difference between atmospheric pressure at your altitude and the "pressure" in the intake manifold. If MP was a pressure in the conventional sense (positive), air would flow out of the intake manifold back to the atmosphere - bad deal. It has to be a vacuum for the engine to suck air in.
Am I wrong?
This might just be this engineer annoyed at incorrect terminology, but it seems to me it would explain better if proper terms were used.
Am I wrong?
