Hempy.8
I'm New Here
I cannot level/adjust the roll indication on the gyro. I push in the lower right knob as the manual says but it will not level. Everything else works great. Thanks for your help.
Mine did the same...was actually doing that when I bought the plane. I was told it was toast, I replaced it with a G5 for $1300 (two years ago). It was an excellent upgrade.
I don't know if MidContinent is able to do any repairs for the ADIs. Is the bank display what you are trying to adjust or the way the autopilot flies when in bank angle mode?
Yes the display
Yes I am trying to level the display while sitting on the ground. The autopilot works perfectly otherwise. Thx
