Well, for what it's worth I have been using the adjustable set with the thin nose yoke for the entire build whenever I've needed it. It's always worked fine.
I just started having this problem during my rudder build.
Isham had this to say:
> Justin,
> You cannot use the adjustable set holder with the 4" thin nose yoke. Use the fixed set holder that came with that yoke. The adjustable set holder only works with the 1" base yokes. This will not set rivets properly and will potentially mess up the threads on your adjustable set holder. See this link:
http://www.planetools.com/Yoke-Base.htm
> Also, if the rivet you are setting is too long this can cause them to bend over. Don't rely on Van's rivet length callouts.
> Let me know if this corrects the problem.
To which I replied:
Well, I tried using the fixed set holder. Interestingly I still seem
to be having the same problem. I've actually never used the fixed set
holder before.
I snapped a couple pics which I've linked below. Used three washers
and my longest flush set on a 3-3.5 rivet. There is still a noticeable
angle when the set holder is fully extended. You can make it out in
the second pic and can definitely feel it with your fingers.
I also tried setting a 3-3.5 rivet using this setup just for the heck
of it. Sure enough it folded right over like all the others
I've
set at least a hundred rivets with this squeezer and just started
having this problem while working on the rudder. Very frustrating. I
hope I'm just doing something wrong but I cant think what that might
be.
Thanks for your help and insight,
Justin
https://dl.dropbox.com/u/49973161/2012-06-05_20.19.02.jpg
https://dl.dropbox.com/u/49973161/2012-06-05_20.19.24.jpg
We will see what becomes of that.
Justin
