... and even buy a pesky Mac thing![]()
I will be releasing a weight and balance iPhone app to the app store soon and this thread made me consider adding RVs. For other aircraft I can look up a U.S tail number and find an FAA Type Certificate that contains a W&B envelope. However, for RVs each aircraft appears to be build by a different manufacturer (you) and I am having trouble automatically looking up type certificate data.
Does each aircraft have its own type certificate?
::Ken::
Full disclosure: I fly a Cirrus.
::Ken::
Amateur-built aircraft, like RVs, don't have a type certificate, as there is no official approved type design. So don't waste any more time looking for Type Certificate Data Sheets.
But, Van's Aircraft does provide recommended weight and CG envelopes for normal operations, and a reduced weight/CG envelope for aerobatics. It is up to each builder to do the flight testing to determine where he will set his weight and CG limits, and it is quite possible for builders to chose weight and/or CG limits that differ from those recommended by Van's Aircraft.
Or, contact Van's. They may be willing to send you copies of the info they give builders on recommended weight and CG envelopes for each model, and the length of the arms for variable weights.
If you want to make a weight and balance app for RVs, the folks on this site can certainly tell you the recommended weight and CG limits for each model and the arms for the various variable weights. It would make sense to use these as the default, but the app should allow the user to enter his own weight and/or CG limits if he has chosen values that differ from those recommended by Van's.
Two more complications:
- the recommended gross weight for RV-9s and -9As varies depending on which engine model is installed.
- the aerobatic gross weight for RV-8 and -8As depends on when the wing kit was delivered, as there was a design change in the wing spar part way through production (this may also apply to early -7s and -7As, as they share the wing design with the -8s).
Weight and balance data for all Van's models except the 3 and the 12 are available here:
Vans W&B Data
You will find it just over half way down the page.
What Kevin Horton says about builders being able to decide on their own weight and CG parameters may well be true in the US and Canada but it is certainly not true here in Europe. The RV-3B is limited to a max weight of 1175lbs in the UK for example.
Anthony,
Thanks for the info. Looks like only a couple of dozen total (recommended) configurations if you include aerobatic configurations as well as two engines on the -9s and wing options on the -7s and -8s (as Kevin mentioned). Bottom line: for any specific aircraft there is not a lot of data to enter in any case. I'm used to dealing with not-a-rectangle envelopes, gear retraction moment changes, and non-linear fuel-moment relationships that require a long table of data.
I'm definitely not, however, used to being test pilot and determining my own limits. Scary... Hats off to you guys!
::Ken::
