GhostRider32
Active Member
Hello all,
I just purchased an Ipad and am looking at getting a strap around the leg kneepad for it. Do you guys or gals have any suggestions for one that will accept the iPad Air with a protective case already on the Ipad? Thanks in advance.
Hello all,
I recently did this, too. I found an old knee board with a strong clamp at the top. It also has two slots for the strap so that the strap does not go over it except right at the edge near the slot.
I did find that I have to tie the strap to my leg tightly because the velcro was not short enough nor strong enough.
The clamp at the top, intended for holding a pad of paper, doesn't hit the screen because it presses on the case's edges.
I left it at the hangar but if you need pics I can get them when I go back there in a few days. On request.
I use one similar to this one. Simple light and fits about any tablet. You can switch between portrait or landscape layout without having to make adjustments.
https://www.sportys.com/sporty-s-classic-kneeboard.html
https://www.myclipforipad.com/
Hello all,
Get a myclip https://www.myclipforipad.com/ designed by Jim Peters - formerly USN F18 pilot. I’ve used one for years and works great. I particularly like the Military MyClip with Buckle (MK-FB).
