YellaDawg
Sponsor
Anyone that has installed a IO390 EXP119 or 289 with Airflow fuel injector (FM200), what length control cables did you use and where sourced. Firewall penetration on left side mid height.
Thanks in advance,
YellaDawg
I’m putting an io390 on my RV8 but the non-exp version. I can’t anyway figure out what cables I’ll want I figure I might just have to hang the engine and use stiff wire to measure!!!
Roger that. Airflow offers a bracket that bolts to the bottom of the std IO390 that guides the cables to the controller properly. If you didn't know. Probably want to mount that then measure.
