C Chipper G Well Known Member Feb 2, 2023 #1 Trying to locate what the idle Manifold pressure should be. Can anyone share this data?
bjdecker Well Known Member Ambassador Feb 2, 2023 #2 Chipper G said: Trying to locate what the idle Manifold pressure should be. Can anyone share this data? Click to expand... Idle RPM should be down around 650-700 MAP will support that -- typically < 11 InHg
wjb Well Known Member Feb 2, 2023 #3 I'm seeing 13.5" at ~720 RPM on my G3X (MAP from primer port on #4)
bjdecker Well Known Member Ambassador Feb 2, 2023 #4 wjb said: I'm seeing 13.5" at ~720 RPM on my G3X (MAP from primer port on #4) Click to expand... Your field elevation is a bit lower than mine (66.3ft vs 800ft), that may account for a bit of that difference. Last edited: Feb 2, 2023
