I don't think the engine would have any problems with Mogas and 10 percent ethanol. (assuming compression ratio allows). The problem is vapor lock and ethanol damaging rubber in the fuel system.
If your fuel system were built to withstand ethanol you should be able to run it just fine. My aircraft runs on MOGAS with ethanol but I have a Subaru engine and fuel system components that are ethanol compatable.
-Andy
