Wise choice...
Thank-you very much, Smokey. And thank-you, Chris.
Actually, after many - included Van's personnel - told me an IO-320 is plenty enough power, I am switching into an IO-320.
I will maintain the Catto propeller, though. The MT even two blades, is too much money for me now. And I doubt it is necessary.
Thanks.
Camillo
Camillo,
I flew the IO-320/Catto (1st RV prop prototype) on my RV4 for 10 years. Craig makes spinners pre-cut to fit all his props. You will love it! Catto takeoff climb performance with the new blade design will nearly match constant speed takeoff performance and exceed climb/cruise performance. I recently compared my RVX alongside a 210HP RV7A with a Hartzell BA. With the exception of initial takeoff acceleration I easily caught and stayed alongside in a full power climb to 5K actually throttling back to stay in formation. My cruise power settings were identical to the 7A which has a 40HP advantage. Catto props are bellisimo!
Also, the current Vans pre-preg glass cowling is far superior to any competitors. It fits well, is easily filled, primed and painted and light weight.
When you order your IO-320, consider flow matching or 9.0:1 comp if they offer it.
You have chosen wisely...
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Ciao!
Smokey
Italiano!
Camillo,
HO volato IO-320/Catto (1\'b0 RV prop prototipo) sul mio RV4 per 10 anni. Craig rende i filatori pre-tagliati per adattarsi a tutti i suoi arredi scenici. Vi piacer\'e0! Catto decollo salire le prestazioni con il nuovo design della lama quasi presa con velocit\'e0 costante delle prestazioni e superare salita/le prestazioni in regime di crociera. Recentemente ho confrontato il mio RVX a fianco di un 210HP RV7A con un'BA. Con l'eccezione di decollo iniziale accelerazione MI catturati facilmente e siamo stati a fianco di una potenza massima salita a 5K in realt\'e0 lo strozzamento tornare in formazione. My cruise impostazioni di alimentazione erano identici alla 7A che ha un 40HP vantaggio. Catto puntelli sono bellisimo!
Inoltre, l'attuale furgoni pre-preg vetro cofano \'e8 di gran lunga superiore a qualsiasi concorrente. Si adatta bene, e8 facilmente riempito, innescata e dipinto e peso leggero.
Quando si ordina la IO-320, portata corrispondente o 9,0 :1 comp se offrono.
Si \'e8 scelto saggiamente...
Ciao!\
Smokey}
