1bigdog
Top of the IO-320-D1A are 1/4" crankcase bolts. I need to get a few longer ones but can't seem to find a part number.
The parts catalogue seems to show an image of the correct part with a "U" hoist point associated but no number assigned:
figure 1-1 crankcase assembly - right side of image, left of part #15
https://www.lycoming.com/sites/default/files/O-IO-LIO-320 Parts Catalog PC-103.pdf
Any idea what these bolts are or what their equivalent is?
Thanks for the guidance.
Look 6 pages further at figure 1-5, crankcase attaching parts. There they specify what is used which is 1/4-20 by X length.
Look for ms equivalents, more reasonable.
MS90725 Grade 5
MS90728 Grade 8
Which grade ?
MS90725 Grade 5
MS90728 Grade 8
I appreciate the addntl reference. There seems to be some debate about what grade those bolts are. I don't think that was ever resolved.
From what I've researched the lycoming bolts are 123000 tensile strength, C26 Rockwell hardness minimum, C32 max.
Grade 5 have 120000 tensile strength, C25 min, C34 max.
Choose enough for me to hold the case halves together.
Is there a downside to grade 8
I'm assuming you meant "close enough". No argument from me. Let me ask a more basic question. Given the superior qualities of grade 8 (the NAS equivalent) is there a downside to using MS90728 for this application?
yes i meant close enough lol
The grade 8 ms bolts are zinc coated not cadmium like the 5's. besides cost I don't see a downside, but I'm not an expert lol
