Flying Sunday from Santa Barbara to Portland. Great weather, smooth air.
Got an intermittent over voltage alarm on my GRT EIS and EFIS. Meter read up to 15.2 V on the main bus. (Dual batt, dual alt setup.)
I switched off the main alt and switched on the cross feed so that the B/U alt was carrying the whole load. Voltage went back to normal.
Flew like that for a few minutes then switched off the cross feed and switched the main alt back on.
Voltage slowly - over 15 min- went back up into the 15V range.
Repeated the cycle and the second time around the voltage remained in the normal range for the rest of the flight. (about 5 hours)
Where do I start looking for the problem?????
have B+C alternators and external regulators.
Duane
Duane
