David_Nelson
This is not meant to be a primer/paint debate entry. I'm only passing on the results of a simple experiment that I performed to see what would be more durable: aluminum w/ GBP-988, or a roughed up surface.
For some time, I've been thinking about what color I wanted my interior paint to be and I find the beige colors quite appealing. So, as an experiment, I went down to the local home improvement store and purchased a can each of Rust-Oleum #7770 Almond Gloss, Rust-Oleum #210372 Biscuit Appliance Epoxy Gloss, and finally Rust-Oleum #7758 Almond Satin.
I proceeded to make six samples out of alclad aluminum sheet (a former elevator skin), three cleaned and prepped w/ Sherwin Williams Self Etching GBP-688 Primer, and the other three scotch brighted and cleaned. All the samples were cleaned w/ laquer thinner just prior to any primer/paint.
After about 5 weeks to dry/cure, a simple "thumb nail" test was used to see if I could lift the paint from an edge or corner as this is where chips would normally start. Would you believe that all the samples that used the GBP-688 stuff failed! However, I was unable to peel any paint away on all the samples where the surface was roughed up, cleaned, and then painted. Go figure.
Now the question is, glossy or matte?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here's hoping this helps somebody down the road....
