Repeat: ID steel parts, Degauss and Swing
bamadude said:
There is not presently a whiskey compass in the aircraft. Too much interference.......A pedestal mounted compass has been placed, (not mounted) on the glareshield and is not even close. A panel mounted has been tried with unsatisfactory results. Brands tried unknown. I would prefer to mount the compass in the panel. Thanks to all for your help.
Look Dude: you got to do the steps. If you want it in the panel than put it there, but make sure there are no electrical instruments adjacent. Altimeter, airspeed, VSI are fine. Vac instruments, ATT/DG, MAP, OK. Worse are motors (T&B) and next are avionics like Com's.
I don't know what you mean "not even close" means. You have not qualified how bad the interference is, but it matters little until you try to at least swing it.
It will not be correct until you follow the steps:
DID DEGAUSS THE ROLL BAR/CANOPY FRAME?
DID YOU SWING IT?
DID YOU ASSURE NO STEEL NEAR IT?
USE NON-FERROUS METAL TO MOUNT AND ADJUST COMPASS
Look I mentioned you need to degauss the roll bar. This is common. You need to ID any steel or ferrous material in the area. Than you need to makes sure it is not magnetized (degauss). Once that is done this you install the compass, with brass or stainless steel screws and swing it. After you do that let me know how it comes out.
Here is how to swing the compass:
http://www.airstuff.com/compass.html
Here are some tips:
You NEED to swing it (with a brass screw drive, and may take a few tries)
Use a magnet and find all the steel any where near the panel/cockpit. Than use a small handheld pocket hiking compass. Move it around and see if you can find the magnetized parts. (A real Magnetometer or gaussmeter),
http://www.trifield.com/gauss_meter.htm A little hand held passive one sells for like $50,
http://i24.ebayimg.com/02/i/05/c5/32/d7_2.JPG
My guess its the big steel items like the canopy bow, engine mount and maybe the engine crank. Any steel bolt/washer can be a magnet. Yes the engine is a magnet, however it is fairly far away, but you can account for it with the correction magnets. Look a steel ship has a compass. How? With real big correction magnets.
You (likely) have to Degauss the steel in the cockpit area. I think Bob N. of aeroelectric has a degaussing coil he lends out, I think? Google the subject and degaussing and compass swing. Good Luck I am out of ideas.
Sacramento Sky Ranch rents out their degauss-er for $75.
Here is their article. Magnetism of steel is a real thing. Trust me degaussing helps.
http://www.sacskyranch.com/degauss.htm
Here are pictures of the steps (hit next near the picture, the movies did not work well for me)
http://www.sacskyranch.com/degaussi.htm
More info
http://www.kilohotel.com/rv8/article.php?story=20040303210952285
Steel Boats and the physics of magnetic compasses
http://pollux.nss.nga.mil/NAV_PUBS/APN/Chapt-06.pdf
COMPASS TYPE
I had an electronic compass I tried in my car, which is of course all steel. It had electronic swinging. You drove around in a big circle twice in 30-60 seconds and pushed some buttons and it corrected itself. It worked OK for a week or so, but I got tired of it. It seemed to get out of calibration and got sick of going in circles to calibrate it, which some times I had to repeat two/three times to get right. I did not replace the battery when it died.
One of those electronic compasses may work for you. However if you are mounting a compass in your plane spend the bucks and get a good one or a surplus WWII airpath. Some people use car compasses. Boat compasses are kind of big and they are not cheap. I would not know how a boat compass would work.
SWING
You have to be level if its a tail dragger and ideal engine running and electrical on. That can be hard to do. You need people holding the tail up with the engine running. You can compromise and have the engine off and the the tail up, or the engine running and tail down. Always have the electrical equipment on. The idea is to represent the typical (cruise)condition. Like I said my RV-4 compass swing wild when I transmitted. I just ignored the compass when I transmitted.
![](/community/proxy.php?image=http%3A%2F%2Fimg433.imageshack.us%2Fimg433%2F293%2Frvint011rf.th.jpg&hash=e64b3b46633a839a7ef61e8798f67a37)
click me to enlarge
Look if you install it and your swing gets you within +/-5 to 10 degrees on all cardinal headings N,S,E,W, and NE, NW, SE, SW you are doing OK. It is what it is. Just average out the error with correction magnets and live with it.
I am sorry you are having problems but degauss, swing and use an aircraft quality compass with a S-N and E-W compensating adjustment. I am done. Good luck.
There is one possibility is check the Magnetic Geological anomalies at your airport. It does little good to swing a compass in an area of magnetic disturbance. Chances are you are OK, but you can check it out. Sometimes the sectional will show Mag disturbances or the AFD (Airport Facilities Directory) will mention magnetic anomalies at an airport. These can be like 20 degrees!
http://www.ngdc.noaa.gov/seg/geomag/jsp/IGRF.jsp
http://geomag.usgs.gov/
http://science.nasa.gov/headlines/y2003/29dec_magneticfield.htm
It will never be perfect but as long as your compass does not think you left wing tip is the North Pole you will be fine.
George
