macrafic
When I put the bushing blocks on the canopy latch (long bar with the fingers on it that spans the cockpit behind the seats) and try to place it up against the 705 bulkhead, I get interference from the flap motor housing.
I'm sure I'm not the only one that has experienced this (hope?). How have you all resolved this? Would it be OK to put a spacer between the bushing blocks and the bulkhead, which would move the latch forward? How much room do I have here before I would hit the installed seat pan when it is in its most aft position? Is there a better solution?
