renesis.rv7a
I'm New Here
I've seen people talk about flying instruments in RVs, but I was reading the 2007 FAR/AIM today and saw the following:
S 91.319 Aircraft having experimental certificates: Operating limitations.
(d) Each person operating an aircraft that has an experimental certificate shall-
(1) Advise...
(2) Operate under VFR, day only, unless otherwise specifically authorized by the Administrator;
Is this even an issue for RVs? Does the DAR give this authorization, or does it come from elsewhere?
Your DAR should include that "After completion of phase I flight testing, unless appropriately equipped for night and/or instrument flight in accordance with part 91.205. this aircraft is to be operated under day VFR."
This allows night and/or IFR if appropriately equipped.
Mel, if I read and understood that correctly;
Upon completion of the test I can equip my plane accordingly for the conditions (IFR) and venture into the clouds without an additional test phase?
Do I have this right?
:confused: CJ
