georgemohr
Hi all,
I'm trying to lay out my G3X LRU's on a mockup of the panel, and I'm concerned about clearances to various structures. The below indicated bracket isn't clear to me how it is used in the final assembly. Does something mount to this structure, and if so, what kind of clearance from it should I maintain? Or is it just a stiffener for the panel standoffs?
Thanks!
George
Electrical plugs if you choose to use them . I never have . I switch from AMP connector to Sub-D connectors for better connection in My opinion. If you omit the bracket you should check with Van's to make sure the bracket is not part of the bigger picture in the structure.
Circuits involved in connector:
Canopy Open warning circuit
Glareshield LED lighting
Defog/panel cooling fans
AOA if glareshield mounted indicator
