I tried to search for tips for installing WH-00125 and found none. I am at wits end trying to install this harness. What have you done to get the wiring thru the holes as the connectors are all larger than the holes. At this point I'm thinking about cutting the wiring, install thru the holes then reattach with D-subs and cover with heat shrink.
Thoughts and PICTURES are greatly appreciated.
Thanks for your help!
