walkman
I installed a GRT (really Tru Track) pitch servo in my -6 today. Installed it in the same place as the Tru Track Alt Track I just removed. Its basically the same setup, but a different servo.
Anyway, couldn't really find good installation instructions. Some mediocre drawings on the Tru Track site.
To build the push rod I installed: Rod End, washer, jam nut, rod, washer, jam nut, rod end.
On the servo arm I installed bolt, washer, servo arm, washer, rod end, washer nut.
On the control arm I installed bolt, washer, control arm, 2 large washers as a spacer, then a regular washer, rod end, washer, nut.
It all seems fine, smooth, nothing rubbing or fouling etc. I have a short piece of rod left, about 1/2" long listed as a spacer on the inventory.
I'm inclined to think it might be used in a different installation, can't figure out how to install it on mine. But, thought I'd check here.
