I totally agree. Just prior to working on the cowls, I installed the spacers. I just did not feel comfortable with those spacers knowing from experience how minute differences on one end can magnify seemingly small errors by the time you get around to the other end. So I removed the spacers and installed the (constant speed) prop for TRUE reference prior to trimming the cowls. The blades are positioned horizontally 99% of the time anyway and is no big deal to work around. Even Van's recommends using the prop if you have one. The cowling fits so well that NO uneven gap exists.... most particularly the gap behind the backplate and cowl that might otherwise require filling and sanding etc. to account for engine offset........The prop doesn't interfere with the cowling 1 iota........Jekyll
I may be wrong here but I assumed they were talking about the prop spacer, which is not included in the kit.Ward,
Sorry for the ignorant question but... what spacers? I'm getting ready to install my engine and don't see any reference to spacers.
Yea, I agree. Sure, a spacer is a spacer but cutting each to the precise length......therein lies the rub......... I thought about using the spacer method but I had too many occurances of measure twice......what a nightmare trying to find the equidistant spacing of the 6 screws on the front plate, is it "2 pi r" or "pi r squared Jekyll
James_RV60436
I am just about to install my top cowl and was reading your post on cowl installation and noted that you said you positioned the cowl 1/8 inch above the spinner to accommodate future engine sag. ..."....I set the top of the cowl 1/8 inch higher than the spinner backplate ..."
To plan for engine sag I think you need to install the cowl below the spinner, not above. The cowl is fixed and will not move once installed. If the engine sags, the spinner will move downward while the cowl remains fixed. Hopefully they will align.
Mike Draper
RV-8
N468RV
Finish
Bridgewater, MA
