Bleeding..
The logic on bleeding by pushing fluid up from the calipers is that he air in the system will try to rise. The distance, top to bottom, where you are going to try to push the bubbles down, is longer and more convoluted than most cars. I'm not saying it won't work, it is just much faster to gently pump some fluid in from the caliper end. I can bleed the brakes on my '8' in 20 minutes.
John Clark ATP, CFI
FAA FAAST Team Member
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
