jeffreyuh60
Active Member
All,
I am ordering Infinity Grips and am installing the ACM from Advanced Flight. Do I need to order relay decks for trim and flaps? I spoke with JD from Infinity last night. He stated that he is not familiar with the specifics of the Dynon/ Advanced Flight ACM.
I will ask the same question of Advanced Flight this morning.
AFS/ACM needs no relays
You don't need relays if you are using the Advanced Control Module. The relay is needed in planes that direct control the trim motors, but not needed in a system where the wires off the grip are carrying only signal -- such as with the ACM.
All,
Thank you all for the replies. Rob Hickman (AFS President) stated moments ago ?You do not need relay decks, they are built into the ACM-ECB.?
I love this forum.
Jeffrey Turner
