p51dplt
I have an Infinity grip with only the PTT wired currently and would like to wire the flap toggle switch. I have a momentary up/off/down switch in the panel with all 6 poles wired, with the opposite corner poles jumped together.
Do I need a relay of some sort or can I make this work somehow? Not the brightest when it comes to wiring....
Thanks.
A schematic of your current wiring and a datasheet for the Infinity grip will help. A relay or two will probably be required.
I think that since the stick grip has a single pole switch, you'll need a relay or the Flap function on a VP-X.
I'm sure I'm a little late to the party with this but Digikey part number CKN1144-ND is a DPDT switch that I had put into my infinity grip that eliminated the need for a relay and worked great.
