Michael Burbidge
I'm going from a Sky-Tec LS starter to a B&C starter. The B&C starter is about 3.5 lbs. heavier.
Unfortunately my fuel tanks are full. To do a from scratch weight and balance would require that I empty the tanks! Ugh!
It seems that mathematically you could calculate a new weight and balance using the change in weight and position.
Is that true? Is that legal?
Michael-
Incrementally is normally how it's done.
An example from my Sky Arrow:
As an aside, shows the gains possible from switching to a lithium-iron battery!
And although no-one has mentioned it yet, do it in an Excel spreadsheet to keep the mathematical calculations correct...:)
And I see the image above was created in Excel.
In Excel
My original W&B is in Excel, so I can just go from there.
The B&C starter shows the CG for the starter in the drawings. The Sky-Tec does not. I'll just figure that out myself with some experimenting.
Michael-
Michael-
This CG location came from a Sky-Tec supplementary installation document -
Weight and Balance Calculation
Fore-Aft CG: Half the distance between the front and rear starter mounting holes (starter datum)
http://lib.store.yahoo.net/lib/stylespilotshop/sky-tec-starter-install.pdf
Is there really 3.5 lbs difference? I checked the B&C website but could not find the weight of their starters.
