pierre smith
Yesterday, while shooting an ILS during my instrument refresher, the LOC needle on the Dynon's HSI page lay left-to-right, instead of vertical, as it should. It works fine in VOR mode but we couldn't figure out how to turn it so it was vertically oriented. The SL-30 disables the OBS knob in LOC mode.
According to the Dynon manual, it says to set the course using the softkeys below the HSI. Well, I just got out of the airplane with only the Dynon turned on and couldn't rotate the HSI. All I found were the BUGs settings. Maybe Dynon means set the bug when it says "Set the course"??
How do you rotate the HSI in LOC mode? Or can you even? I just want the LOC needle vertically oriented.
