Frank Smidler
I have the engine baffle ignition wire seals from ACS. I also have Slick Mags with thier ignition wiring. The wires for the Slick Mags fit loosely in the ignition wire seals. I don't really want to goop them up with sealant but I also don't want them to be loose to slide around and to allow coolant air loss. What have others done here? Just leave them loose? Put a short pcs of tubing over the wires were they pass through the seal? Your help is appreciated.
