Curious if anyone could explain if it is possible to load a flight plan from foreflight for an IFR flight WITHOUT the $1400 flightstream/card solution.
It seems you can load a flight plan from foreflight into the AFS-5600 but then you are stuck with the AFS navigation which is not WAAS.
It seems the AFS cannot tell the GTN650 what the flight plan is, or use the WAAS data when using the internal plan?
This is all new to me so sorry if I’m not making sense.
I guess you could load the flight plan into the 5600 and just switch over to the GTN navigation for the approach?
