Here is my panel
... A couple of notes. The 1101 is fully WAAS IFR Certifiable (it meets the TSO requirements) and it will allow IFR approach and enroute, including LNAV only, LNAV-VNAV and with a future software upgrade, it should also allow for LPV WAAS approaches. These are all the new nomenclature for approaches under WAAS.
The 430 would give you, today, TSO-129a or non-WAAS enroute and approach capabilities (redundant with the 1101). It would also give you a comm and a nav. It can also be purchased today without WAAS, or if you wait, upgraded later to the "W" version which would then support the WAAS features (and would be redundant, but perhaps that what you are looking for, with the 1101).
I elected to put in an sl-30 instead of a redundant GPS/Comm/NAV, I saved the money and installed or provisioned for the portable 496.
The AP that you've chosen also is somewhat overkill, but depends on your applications. I instead elected to save the money and put the Digiflight II VSGV in my panel. It supports all of the features of sorcerer, when used with the Cheltons.
You'll also see the MVP-50 (EI engine monitor) in my panel. Not sure if you are going this way or not, but it provides for other niceties like flaps indication, trim indication, multiple buss, fuel, etc monitoring and intefaces with the Chelton and it's CAWS (Cautionary Audio Warning System).
Don't know what they get for the Pitot tube that you mentioned, I'm a dual alt/buss 24v system and so I elected to go to the standard pitot tube.
As for the AOA, I'm using the ACS Pro version. The Chelton also provides a software version, but I'm not sure they are completely the same. The Chelton does not interface to the external AOA.
As for Transponder, I decided to save my money and only install a Mode C version. Yes, Mode S is nice, but the FAA is actively removing it from their radar environment. Here in ATL, we've lost it in 2 major area in just the last few months. Instead, I'm going to go ADS-B down the road. The Chelton already supports it.
For sure the comments about putting both displays in front of you is the preferred way to go.
So, beyond that, drop me a note and we'll exchange numbers and can carry this on directly.
