majuro15
Hi Everyone,
While flying a few RNAV approaches, I've had a fault come up saying LPV Unavailable, Use LNAV MDA (or DH) followed with a note that says GPS is not in SBAS. I then lose glide path guidance.
I'm thinking what this means is the GPS has lost WAAS and the accuracy level needed to navigate the LPV approach. Am I correct in this assumption?
Now, why? I have my antenna (both WAAS and AFS for my EFIS) under my cowl. I am thinking they are blocked by the skybolt flanges since I have the antenna only 1" from the firewall. My guess is they are able to get good signal through the cowl itself but the metal of the brackets and receptacles are blocking the signal. I have found that during steep left turns, I lose GPS signal as well (the antenna are on the left side above the engine mount.
I know others have had issues with antenna under the cowl and some have not. I'm going to extend the shelf forward to provide a better path for GPS signal and see if that helps.
Just curious if my guess on what is happening is correct.
Thanks!
Thanks!
