T tx_jayhawk Well Known Member Oct 20, 2019 #1 What difference in idle RPM do people typically see between a hot and cold engine? Is 200+ RPM typical?
V Vlad Well Known Member Oct 21, 2019 #3 100-150 depending on the OAT. High time Lycoming O-320 cable driven tach.
T tx_jayhawk Well Known Member Oct 22, 2019 #4 For those out there with injected engines....what do you have min RPM set to at cold (or hot)?
R Robert Sailor Well Known Member Oct 22, 2019 #5 Cold is not that much different than hot, around 700 rpm with mixture extremely lean on the ground, very smooth. IO-320
