Boring holes through the sky 7-8 hrs at a time provides more than enough time to daydream about mod's for the RV...
Lately I've come up with a few and imagine at some point others have already tried or considered trying so I was hoping for some feedback. I apologize if the ideas have been well documented in previous threads I may have missed.
First, because my -8 is currently unprimered, I've thought about finishing the interior with a quality 3M vinyl wrap. I know there has been much discussion about primer and benefits of such, but I was curious if I should primer first, then scuff for adhesive and apply the vinyl or apply the wrap directly to the aluminum surface. The benefit I forsee with vinyl wrap, is that it will finish out the interior more aesthetically without the extra weight of carpet or leather upholstery. Also, there is a very wide range of designs available to include custom with vinyl. Thoughts?
Secondly, for the gearheads out there, has anyone considered using a wideband air/fuel ratio meter to lean for tuning rather than using archaic temperature tuning? I know 'lean of peak' and temperature tuning is a reliable and well established method, but the availability to tune to stoichiometric could squeeze some extra efficiency out while still monitoring safety margins with CHT's and EGT's. While most UEGO sensors operate on partial pressures, which would be slightly skewed at altitude, a correction chart or factor could be employed to get accurate information at high alt cruise. The sensor/gauge combo's are cheap ~$200, and run off of 12V. A stand alone knock sensor with annunciator light might not be a bad safety investment as well, especially for those who run auto gas and aren't always sure of the quality of fuel they are running.
Anyway, I appreciate the feedback. Looking forward to the freedom of some VFR stick and rudder flying again. Have fun at OSH, looks like work kept me from going again this yr.
