ariel_arielly
Active Member
Hii all.
I'm about to produce a new AUDIO PANEL to my -8A.
The audio panel is to be connected to the ICOM A200 Radio, actually, to its rear edge connector.
Since I don't have access to the panel right now, I would like to be adviced by who is familiar with this issue (the ICOM installation manual don't identify the P/N of the connector except it is "MOLEX").
My question is: "What is the MOLEX P/N of the connector, or, at least what is the spacing of the teeth on the PCB?"
Thank,
Ariel
EDGE CONNECTOR
Thank you for your fast answers.
On the picture of the connector at Spruce I could see the P/N:
CR7E-30DB-3.96E.
The "3.96" in the P/N means - spacing between teeth is 3.96mm.
Thanks again,
Ariel
