Pilottonny
It is not in the drawings, has anybody else made the same mistake? Read on!
I have finished the fuselage for 95% and started on the wiring, installing AP-servo, Strobe power supply, etc. I am running my wires, pitot- and static tube, etc. behind the CAD- side panels, so I installed the F-704K upright cap strips on both sides, because the wires run in front of them. I know, there is 3 skin-rivets on each side, that will be riveted later and can?t be bucked anymore, but since Van?s told me every solid rivet may be replaced by a pulled rivet and you would need a specially made bucking bar for these rivets anyway, I figured I would put some pullet rivets in there, anyway.
But today, when I browsed through the drawings that came with my finishing kit, I noticed that the roll-over-protection-bar is fixed with 4 bolts, 2 of them being installed behind the upright cap strip!! (slider canopy!) Obviously I do not have access anymore!
I checked all the drawings but did not find any mention of these cap strips to be left off till later (if installing a slider canopy) at all!
Has anybody ales made this same mistake? And how did you correct it (drill out the 72 LP4-4 rivets? , or make a hole in the cap strip to install the spacer and nut?)
Any input would be appreciated.
Regards, Tonny.
Regards, Tonny.
