Av8torTom Well Known Member Feb 14, 2015 #1 I'm installing my flap weldment and wanted to be sure I had the F-680 block oriented the right way around before I drilled the holes. Thanks, Tom
rvbuilder2002 Legacy Member Mentor Feb 14, 2015 #2 If you mean which direction does the wider portion go? I think it is pretty clearly shown in a drawing view, but yes it goes aft. If you orient it fwd you will see that it would not lay flush on the seat pan because it begins to slope downward.
Av8torTom Well Known Member Feb 14, 2015 #3 Thanks Thanks Scott - for some reason my drawing shows a symmetrical block, but it certainly makes sense to have the longer section facing aft.
