jmartinez443
So I'm removing the rear of the baggage compartment on my QB8A and I stripped 3 out of the eight screws that the crew in the Philipines had put in to hold the baggage compartment.
But I digress, I'm thinking that I want to start using torx screws to fasten my baggage compartment and floors and I have two questions:
1) Does anyone have a good source for torx screws (I found them at McMaster but I'm not sure if I'll be able to order)?
2) What's the best finish to get to use on alum (steel, stainless steel, zinc plated, black oxide, or none of the above)). I'm obviously concerned with minimizing corrosion due to dissimilar metals.
Thanks in advance,
Thanks in advance,
