Dandlac58
I just bought a 2004 RV7/7a... I say both because it has the necessary mounts already on the airplane to make it either a tail dragger or a trike. Yes, cool, the only reason I bought this particular airplane although it was also well maintained and quite nice, inside and out.
Because it is currently in tail dragger gear and tail draggers are inherently far more dangerous than trikes on take off and landings...yes, it's an opinion - but one just validate again at our local airport when a C-170 driver learning to fly it, just last week ground looped it!! Im converting it back to 7A with hopes of lots of fun flying and greatly reduced stress on taxi, takeoff, and landings!!
I am not nearly smart enough to build an entire airplane and anyone who has done it, I revere! You all are awesome!
But I am, I think, capable enough to do some things like what Im attempting on converting it back to 7A trike.
I did the SB for the nose gear and have gotten the modified leg and new fork back.
Im ready to install it into the nose gear mount but seeking advice before doing so. My plan is to insert the leg in the mount using marine grease to lub and protect against corrosion, then lock it in with new bolt and nut. Then install the fork, then the wheel and tire. I've also sent for the installation/build documents from Vans but haven't received them yet.
Any suggestions for doing this to minimize grief are greatly appreciated.
Dan
Dan
