For what's it worth, been painting airplanes, helicopters, trucks, cars, boats and a myriad of other things for the past 40 years.
Both systems work well except one caveat with the turbine..."ORANGE PEEL".
The air is hot coming out the hose. Try grabbing hold of the hose fitting at the turbine end...no way you will leave your hand on it to unscrew it.
Three solutions to cool the air:
1.) use two lengths of hose
2.) use a slow reducer
3.) saw a guy using a "cool can"..... a few coils of hose in a bucket of water.
Other than that, the Turbine with the correct spray nozzle will produce a beautiful finish. Used 3 different turbine models and did not see any appreciable difference in overspray vs the conventional HVLP system if the gun is adjusted properly.
Just remember.....the paint job is only as good as the preparation.
