gh6gh6
Member
Does anyone know which adaptor I need to adapt the Harbor Freight HVLP guns to either the 3M PPS disposable cup system or the DeVillbiss DeKup disposable cup system?
Somewhere in all the HVLP posts someone mentioned that the Harbor Freight HVLP guns are clones of the common ??????? gun. I can't remember which and I can't find the post again.
Does anyone know if the 3M PPS Adapter, 16054, Type 18 will fit the Harbor frieight guns? 3M has an adaptor selection website found here...
http://solutions.3m.com/wps/portal/...craft/Solutions/Product/PPS/Adapters/Selector
but it doesn't mention the Harbor Freight HVLP guns.
DeVilbiss adaptors are found here...
http://autorefinishdevilbiss.com/products.php?pg=406
bump
Can anyone shed some light on this?
I'd love to use the disposable paint cup system, but not sure which adapter is needed (if at all?)
Seems a few people on here are using the Harbor Freight HVLP spray gun with the 3m pps cup system. Anyone remember what adapter to use?
Thanks!
Your local auto paint supplier should be able you with the proper adapter. Just be sure to take your HF gun with you.
I love the PPS cups. They are the best thing since sliced bread.
Click on this link to find the cup adapter needed for your spray gun.
http://terrys.net/ppsadapter.htm
ETA - That link doesn't list HF guns. Sorry. A little digging that I did says Adapter #2 should be the one you are looking for.
