hey folks-
Funny, the build is "complete" (hahaha) and still questions to ask. Searched but wanted to pick the brain trust.
What do you all have for hull coverage? With the increase in kit cost, parts and what labor is if something should need to be fixed.
I have a 7A, with a 390 + Hartzell composite prop, decent panel etc. I asked for a $180K hull coverage quote thinking it'd be close should you ever need to replace the airplane.
Just wanted a sanity check from fellow builders. Quote is Mid $2K range (Gallagher) which I don't think is unreasonable at all given I am not instrument rated yet and not a ton of time, but before I write the check I want to make sure I asked around that I am not under or over on my ask.
Thanks!
dan
Thanks!
dan
