billytime1
Team Van's...I drilled a #40 in hs710 and have .190 from the center to the edge. Spec is to use -4 rivet. If I must have a minimum of 2d edge distance, a -4 will be too close. The hs710 is .125 thick. Is there wiggle room for the thickness of the .125 hs710. Or should I use a -3 rivet and be safe using a 2d rule. I know 2.5 d is safest but if I used a -3 I will be between 2d and 2.5d
