Djgeib
Active Member
In the notes on the HS drawing it shows cut out material from the his-609PP to allow room for the elevator control horns to have clearance. It shows a hatched out area and refers to DWG 27A which I have been unable to find. Does anyone have dimensions of how far down the rear spar to cut to allow for sufficient clearance? From looking at it it appears that going even with the second rivet hole would work but recommendation from someone who has installed the elevator would be appreciated.
