Excaptusmc
Member
I'm in the process of mounting my Horizontal stabilizer. Sheet #34 of the RV6 plans shows the skin and first rib fall outside of the F-614 deck. Mine, however, overlaps the deck slightly. If I use a 1/8 spacer and level as per the plans, the HS skin makes slight contact with the deck. Seems to me this will cause wear. Has anybody used a spacer thicker than the 1/8 called out in the plans? If I do, will it cause something down the road to be out of adjustment or dangerous stress in the tail feathers?
Thanks, JL
Thanks, JL
