JonJay
Check your HS-301 skins. One was fine and drilled nicely to the skeleton. I discovered the defect on the second skin while trying to fit it.
The skin was bent wrong. The outboard edges are fine, but the inboard edges measure 19 1/2" and 19" 1/4" respectively to the leading edge.
I could not fit the skin properly.
Back to Van's for a new part.
