TechSupport
Member
Tried searching to no luck, seeing if anyone else has had this.
I have a new RV-8 Emp that I've started. The left HS-00003 had maybe a half of a degree when it was drilled to the HS-702, didn't even notice it until I clecoed the HS-810/814 to the doublers to check edge distance.
It's very, very close on the right HS-00003 doubler and on the left the last couple of holes on the HS-810 side are .195 to .200 (depending how my caliper feels), inside of the minimum edge distance of .219"
Emailed the mothership last week and haven't heard back, just wondering if others have seen this and be told it's okay.
