Why? Corrosion? Fatigue? I think it could be considered the belt and suspender method, but with large dia. battery cables fatigue is not usually an issue like small gauge (larger #) wires where solder can wick down the wire & causes a solid mass that is not flexible.. No dog in the fight just wondering, I'm 50/50 on soldering the battery cable lugs.Everything I've ever read stated that acid core solder was a real no-no.![]()
I'm no expert, but I think the problem is corrosion. Need some expert to jump in here and get me off the hot-spot!![]()
As far as solder vs. crimp, mil-spec calls for "crimp only". The main reason is that the solder creeps up the wire causing a hard point. This causes the wire to break due to vibration. On wires the size of battery cables, this is generally not a problem. Just make sure they are "strain relieved".
BUT - You don't need to buy an expensive crimper to crimp big cables. You already own the most expensive part of a big crimper; your rivet squeezer. See my tools page for how it's done and the results:
http://brian76.mystarband.net/tools.htm#crimper
IMHO, you should crimp, not solder. If you solder, try to minimize how much solder wicks down the wire. Be sure the wire is fully supported at least through the length that's soldered, as the soldered part will be inflexible and more succeptible to vibration damage. .......
Mil-Specs do allow solder... even Martin Marrietta still has a training class to teach hand soldering to MIL-S-4574E
That's super awesome. I'd buy a set of those from Avery in a heartbeat.
mcb
Check out The Terminal Tool. Its a tool that I have developed and put on the market. This tool actually *shrinks* the wire terminal onto the wire.
NO ugly crimping, indenting or smashing. NO soldering. Shrinks the terminal ferrule like heat-shrink and makes a SUPER tight connection.
http://www.theterminaltool.com
Avery also has them. http://www.averytools.com/p-937-the-terminal-tool.aspx
Thx,
Bill
Hello Brian,
The Terminal Tool doesn't include a dieset for AWG-8 because there are already a number of good tools out there that can do small size terminals like that. .
Bill
Instead of spending a lot of money on a good set of crimpers that would handle the larger gages I took a block AL drilled the proper size hole it and then cut in half. Place it in a vise with the wire and connector and squeeze it shut. Works like a charm.
