I'd just use pop rivets in those tight spots. Makes the job a lot quicker, easier, with less damage and mental trauma. I spent way too much time dealing with these on the rudder and elevators and didn't hesitate to use pop rivets on those holes on my flaps or ailerons. Pop 'em and move on!
Buy some real -3 blind rivets and use them (I'm not a fan of those oddball -3 rivets Van's sells). I found you potentially do some major cosmetic damage by forcing a solid rivet, when a simple pop rivet will do. Many airplanes are built with only pop rivets, a couple on your plane is fine.
Cam,
I am just finishing the elevators, I used some blind rivets on the rudder, one on the trailing edge of the rudder (both sides) and the most leading rivet inside the horn brace. I am not sure what you mean about "real blind rivet" The blind rivets I used looked OK but I would like to know what other options are available. If you could post the rivet number and a source if they are difficult to find. Thanks in advance.
Cheers
Van's supplies MK319-BS rivets. They require a slightly larger hole than a -3 rivet. You can get blind rivets that will fit right into a -3 countersunk hole. That way if you come across a need for a blind rivet you don't have to do any extra countersinking and find a larger drill bit. Other than that there is nothing wrong with a MK319BS blind rivet.
I picked up a big bag of them at Oshkosh years ago and I'm not sure what the part number is. Try Spruce, they sell a good replacement for the CS-4 rivets that Van's sells. I believe they are BSC-44. They seem to fit a bit more flush and have a better finish than the CS-4. I believe there is a similar part number for the 3/32 size rivets.
ccc-32 is the best I have found to be a true 3/32 flush blind rivet.
Have you used these rivets, are they aluminum or stainless steel, I think the ones from ACS are Stainless, any problems with that next to aluminum? Sorry this is late but I am setting the blind rivets in my elevators and want to know if these are OK.
Cheers Mike
